Help: on log shaft vs short shaft
snowwboundd
please help,
I have a 1967 100 hp evinrude starlite that is long shaft on a 15" transom boat. I also have a parts motor 1964 90hp johnson meteor short shaft . both have electric shift. can i put the drive shaft from the jhonson into the evinrude aswell as the lower unit or should i remove the extention from the rude and use just the drive shaft bar? the johnson is not repairable...
