Help on merc 115
Gumby1970
Needing help guys 2012 115 4stroke merc.. rough idle an wont power above 2500rpm changed both filters and 3 of the 4 plugs look norm 4th looked new changed that coil out but doing the same...any help? Thank you
jimmbo
Welcome to iboats
Engine needs Fuel in the right quantity, Spark at the right time, and Compression, to run.
So. Do a Compression Test. Check to see if all Cylinder have a Spark that can jump a 3/8" gap, and then the fuel system. Could be dirty/gummed up carb(s). How was the engine winterized? Check fuel flow from pump, and Pressure
There is a slight chance that the Linkages to the carbs are unhooked
