set_the_hook
Thread starter- Joined
- Feb 2, 2008
- 7
I am in need of a couple of thermostats for a 1993 120hp "120TLET"
I looked on this site, but it does not list the 120hp. In looking at the picks. They do not look like the thermostats that I removed. The ones that I removed are black plastic with a screw stud on one end and a spring that is separate from the stats I look on the forum and posters have stated that the thermostats should be replaced with white ones. I am wondering if these are in fact the thermostats, does not look like any thermostat that I have ever replaced in the Auto business before
I have ordered a manual off of E-Bay.
I just bought this boat 19' Predator tunnel that was not used but once a year in saltwater. It started right up, but no water from the tell tale. There is corrosion around the head gaskets, but I am afraid to remove them (Snowball effect) I am a Master ASE auto tech and know my way around.
The question that I have is it worth removing the heads and replacing the gaskets or just replace the pump assy and thermostats to see what happens?
Thanks for your advise on this
Mike
Mike
