Help please -1977 85hp. Vs 1988 88spl parts compatibility
appleo
Hi
I have a 1988 88 hp spl on my boat
Looking at a 1977 85hp as a parts motor
Who can tell me what parts might be swappable in general?
And specifically
Lower unit?
Stator?
Control box?
Cdi?
Coils?
Power trim?
Prop?
Starter?
Any web resources are you aware of that may help?
We're there model years that are grouped together?
Thanks appleo
Re: Help please -1977 85hp. Vs 1988 88spl parts compatibility
Not many parts will fit.----Check this out on -------shop.evinrude.com
Faztbullet
A few nut/bolts as totally different ,,,,
Prop is definitely usable.---Control box will work.-Starter might fit.
emdsapmgr
That's correct. The 85 hp engine is a 92 cubic inch version, the 88 is a 99 cubic inch version. Blocks, cranks, pistons, carbs, ignition, cowlings, exhaust adapters, heads, gearcases, shift mechanism, thermostat arrangements-all different. The throttle/shift cables changed in 1979. The engines just look alike.
appleo
good info thank you
what years span the 99 cubic inch version?
The 95 cubic version ?
jimmbo
the 92.6 displacement was from 1969 thru 1978. In 1979 the 99.8 was introduced for the 85, last year for the 85 was 1980.
emdsapmgr
The 110-115 and larger engines were always 99.6 cubic inches. It was the early 85 and 100 hp engines which were smaller. Jimmbo correctly identifies 1979 as the 99.6 standardization year-all models.
