HELP PLEASE! 2000 50 hp mercury ignition troubelshooting
P3FE
Does anyone know where I can get the troubleshooting procedures for a 50 HP mercury igniton system? It is installed on a basstracker boat and there is no spark at the plugs. I troubelshot the ignition switch and it appears purple is the hot for the ignition in the "run" position. I am suspecting trouble with the voltage regulator maybe...? Can someone help me with troubleshooting the wiring for it? My son bought this boat yesterday, it ran fine and I noticed evidence of a overheated yellow wire at the regulator, and the regulator appears new. I removed the bad wire and spliced it, and it reads coninuity fine. Guess I should have left it alone! Where does the yellow wire go from the volt regulator- I'd like to verify voltage. Thanks brothers!
carholme
Re: HELP PLEASE! 2000 50 hp mercury ignition troubelshooting
Would help to know the s/n as it could be a two or four stroke.
Gerry
P3FE
sorry- it is a 2 stroke engine...I forgot we are dealing with 4 strokes alot now!
P3FE
trr 572 is part number- it has 5 wires
Laddies
Banned
There are 2 yellow wires from the stator under the flywheel to the voltage reg. there is no voltage on them if the engines not running if the reg. is good
carholme
That is not a s/n of the engine. It should look like this:
0G961500 thru 0T780999 if it is a 2000.
I have the manual and can send you a copy if you PM me with the s/n and an email address.
Gerry
P3FE
Got it fixed....thanks for the help. I am almost embarassed to say- my spark tester was inop...and I had to verify spark with a set of jumper cables for the ground, once that was done, it turned out to be fuel related...fixed it and she runs now.
