OK after quite a few threads I have encountered a new problem with my motor. Here is what has been done:
1978 115 Merc 6cyl
Carbs broke down and cleaned, newer model floats installed.
New fuel pump kit
new fuel lines, primer bulb, and motor fitting
fresh fuel with 50:1 Quick Silver oil
Link and Sync
New plugs and wires
Here is the issues that I am encountering, when the motor is cold and in the water idle is right around 1000 rpm (not quite sure it the tach is dead on) It is an easy start. Come off of the dock and idle through the no wake zone, jam the throttle wide open and she screams 5200rpm do not know the speed. Come back down to idle and it does good, hit the throttle again and we are back up and going with no symptoms.
Now stop and fish with the motor now fully warmed up, fish for 20-30 mins and go to restart and it will barely run with the warm up lever wide open, it will never go above 3000rpm. If I am lucky i can get it to run just above idle and get back to the dock, but most of the time I am back to the trolling motor to get back.
A compression test has been done and it was 120+-2psi on all cylinders.
I am completely puzzled on this one. This only happens when it is warmed up, runs great when it is cold.
When trying to restart it will almost pour fuel from the carbs it seems. It almost acts as it is completely flooded but I tried to disconnect the fuel line to see if when it was about to empty the bowls if it would idle up, it was a no go.
I am getting really aggregative with this motor.
I do have a spare motor with all the electronics that are known to be good, but before I start to replace everything I want to have a direction to go.
Thank you for all of your help.
1978 115 Merc 6cyl
New fuel pump kit
Link and Sync
New plugs and wires
