Help Please! my trim will not adjust up so my prop is stuck down
kennyalmy
How can I manually realease the hydrualics so that I can bring the prop up with out unhooking the lines? I have a 1995 glastron with a 3.0 mercruiser 135hp
Silly Seville
Re: Help Please! my trim will not adjust up so my prop is stuck down
Welcome to iboats! This is very simple. There is a release valve on the hydraulic pump that you turn to relieve the pressure from the lines. Then you manually lift (and secure) the drive in whatever position for trailering you would like.
frank246
Whats wrong with the pump?
