Re: Help Please! my trim will not adjust up so my prop is stuck down
Welcome to iboats! This is very simple. There is a release valve on the hydraulic pump that you turn to relieve the pressure from the lines. Then you manually lift (and secure) the drive in whatever position for trailering you would like.
