Last time on the water my water pump froze due to impeller being chewed up. I changed impeller and thermostat since housing was off while checking for impeller pieces. First time out since, I did have heavier than normal load, but noticed that rpms ran higher than usual. Also noticed that engine was running a little over 175. The thermostat is 160. Also had to remove belt to access water pump. Could belt tension effect rpms?
I'm running a 1999 Mercruiser 5.7 V8 with a Bravo 3 outdrive. It's on a 23ft Rinker Captiva Cuddy.
I want to be sure that there isn't something else that could be wrong. Any advice would be appreciated.
Thanks
Thanks
