Ok, so after posting here about some motor noise/vibration the suggestion was to check the gimbal bearing and U-joints.
I did so and found the following. Gimbal seems fine, moves smooth etc. U-Joints were rusty, and I plan on replacing.
Pretty sure the U-Joints need replaced. And I want to replace the gaskets and o-rings. THing is I don't know what to get is there a "kit" to buy? The tag on the out board has this number but I dont' think its the model/sn # not sure 6158972
Any thoughts or help would be greatly appreciated. Also, I assume water shouldn't be getting in there... so what are some of the common ways for it to happen? EDIT: Also this started last weekend, i left it in the water all week not know what was wrong. When I went to the boat today, it had quite a bit of water in it 2" or so. i assume that means something is leaking :0 Although we had a lot of rain, I doubt if that is what it was
