I am running a mercury 115 efi 4 stroke on an SV1900 Sea Pro. Whenever I initially bought the boat in 2007 I was getting 44 off of GPS at 5900 rpms and am now only getting 34-35 at 6400 rpms and hitting rev limiter. I bought a new prop in exact same size and pitch and it's doing the same thing. I also changed out the hub assembly and still nothing has changed. I am currently running a 14 pitch Mercury Vengeance Prop with 13.375 diameter. My question is, could there be anything else causing my rpm issue, or do I need to step up to a larger prop? I would like to be back down at 5900-6000 rpms so I would assume that I would need to bump up to a 16p prop if the prop is the route I needed to go. Thanks for any help on this issue.
