Re: Help please
Sorry for the delay. Just returned from business. <br /><br />Okay, here is another possibility: Is there a chance the hydraulic pump is drawing *so much* current such that it is very heavily loading your alternator/battery?<br /><br />A rough test: If you put your multimeter over the battery terminals with the engine *not* running, you'll see something like 12.5-13.4VDC. When you activate the hydraulic motor for motor up, does the battery voltage fall hard to < 11.5 VDC?<br /><br />Have you noticed the engine "labor-down" problem is worse on engine tilt up versus engine tilt down?<br /><br />Again, sorry for the delay. <br /><br />--Ken<br />Red Bank, NJ
