HELP, Pre alpha upper unit, how to tell gear ratio?
Fordiesel69
I purchased a used outdrive with 1.65 gears. Both the upper and lower housings are cracked, how can I tell the gear ratio's for sure? I can see the gears but I have not stripped the drive down yet.
dubs283
Re: HELP, Pre alpha upper unit, how to tell gear ratio?
count the teeth on both gears in the upper
24 and 24 = 1.65:1 ratio
didn't you ask this in an earlier post??
Fordiesel69
I might have, not sure. I am couting 24 teeth on both gears so this is a 1.65:1 correct?
I wonder what it would cost for a shop to transfer the gears and yoke into my blown 120HP housing? Any idea?
dubs283
I am couting 24 teeth on both gears so this is a 1.65:1 correct??
yes
a lot
they're gonna have to re-shim the gears and re-seal the drive = labor
Fordiesel69
What would happen if I just slapped them in? I know this sounds dumb, but if the shims are simply transfered over in the exact order, wouldn't this work?
Maybe I should just keep hunting for another drive...............this sucks!
dubs283
only if the castings for the drive cases are exactly identical, which is pretty much impossible
it may work, but it probably wouldn't
if the shimming were incorrect the drive would spin and work but you would shred the gears in no time under a load
Bt Doctur
Wrong gear ratio for a 4 cyl.
