help replacing shift shaft lever on 1960 johnson 40hp
jonstanton
Hello
Can anyone tell me how to replace the shift shaft lever that connects to the clevis on a 1960 johnson 40 hp.
Please help!!!!
Thanks all
F_R
Re: help replacing shift shaft lever on 1960 johnson 40hp
Exactly what are you trying to replace, #39?
For that, you have to remove the powerhead, and lower unit, then undo all the rubber mounts and remove the #53 exhaust housing from the outer shell. You also have to remove the outer shifter lever to get it back together.
