I intend to do a lot of work over the winter to my boat but i want to get the best out of her i can this season. She will do around 42mph when im in the boat my self but she has a terrible chine walk at 40mph.
She is a Dateline Bikini (similar to ss16 sidewinder) 15 foot weighs around 660lbs./299Kg
The engine is a 1980 Johnson V4 85hp with PT&T. motor weighs 312 Lbs/141Kg
2 x 110ah batteries 88lbs/40kg
I carry 2 x 22lts fuel tanks. when full weigh 100lbs/45Kg
It will normally carry 2 people 320lb/145Kg
She is used on a loch (lake) when im in the boat my self i carry one fule tank next to me. All other times all the weight bar 1 battery is in the transom.
When getting on plane the boat would be near vertical for around 10/15 seconds.
I have since fitted Smart Trim Tabs. The time to plane is around 5 seconds now but she still chines.
I have the engine sitting in the last hole so she is a high as i can get her without a jack plate. Unsure of the prop.
I have one that will be going on her at the weekend. its a 13 3/4 x 15
Hopefully a bit better i know its not a fast prop but will give her a go.
I will take on board all comments Please advise on this here are a few things i need answers for.
Do i have the engine too high ? its in the bottom hole from the top. The claws for a better word that should sit on top of the transom Sits about 2" above it
Should i move all the weight to the front. ??
She defo needs something????
I will try everything to get this boat set up please any ideas i will love to hear
