sutor623
Thread starter- Joined
- May 23, 2011
- 4,089
Hey guys, my new to me boat has been taking on water. Just a tidbit of info, flotation foam is dry, and I weighed the hull and it matched NADA specs. Boat took on 40-50 gallons of water in 6 hours of cruising/anchoring up. It did this for two trips, and on the second trip I was sure not to let any water enter from topside.
Fiberglass has no cracks, holes or really any issues under the hull at all. I removed and re 4200'd all the thru hull fitting in the transom, and installed smart tabs and two new transducers. I was super sure to seal everything very well. I went into the water yesterday and did not see any air bubbles coming from out of any thru hull fittings.
There is an odd little drain in the anchor hatch, but I'm not sure exactly what it is for, seeing as the water that gets into the hatch drains right into the bottom center and into the bilge. Attached is a picture of the hole outside and inside of the anchor hatch. Also, you can see in the last picture, as the boat slows down, or if there is any weight up front (people) while the boat is at rest, I believe this little hole goes below the water level, but what the heck is it?? Maybe I should just plug it? I wish I thought to check it yesterday when we were anchored up and friends were up there hanging out. Any insight would be much appreciated!!
