Help. smoking when trying to start
Lukiebs
Motor has been sitting for a few months and when i went to kick it over the is no spark. But did notice a puff of smoke and crackling from the bolt/nut in the pic.
Please help me!!!!!!!!!!!!!
Lukiebs
Forgot to mention its a 1995 90hp ocean runner
Bosunsmate
The engine wont spark until the rpms get high enough and if your starter isnt operating properly it wont get to that speed. Is that bolt shorting out the +ve wire of the starter?
Lukiebs
No Title
its arcing at the top nut in this pic. Should i take apart and sand or clean the connection point?
Bosunsmate
I cant quite see it, but if the insulating washers etc wear or the plastic bushings get carbon tracking through the little cracks in them then the high voltage will travel from the t ve bolt/nut there and short to the cover base of the starter which is neg/ground
Bosunsmate
You should take apart and inspect,
thats the connection to take apart
Lukiebs
Look like I'm missing the lock washer. Is this plastic or metal?
Chris1956
Honorary Supreme Mariner
Gee, Smoke in that area could be electrical wires burning. That comes from resistance. Clean up all the connectors. Inspect the wiring insulation for breaks and bare wires.
F_R
Heat & smoke at electrical wires or connections are caused by high resistance (loose or corroded connections) or wires that are partly corroded away, or unusually high currents. In this case, probably one of the first two.
