HELP Spark Plugs for 72 mercruiser 140 DONT FIT
Ryanlewis2010
Hi guys im trying to find some plugs for my engine a 72-75 mercruiser 140 the manual says to use mr43t, it currently has RN14YC by champion. I am not sure if this is why i have a bogging problem in my boat under load is really bad it feels just like it did in my car when i had bad plugs. any problem using these as i will be getting the right ones in a lil bit i feel these are the problem because its not hot enough to burn the excess fuel when accelerating this is the last thing i can think of let me know please.
What are you using?
Ryan
Don S
Re: Spark Plugs for 72 mercruiser 140
Junk the champions, put in the correct plugs and see how it runs and go from there.
I have fixed a lot of issues over the years by getting rid of those sorry champion plugs.
Ryanlewis2010
ok so ill go with the ac delco plugs hopefully thats it i think the heat range is to low
cr2k
+1 on junking the champions. They are for OMC outboards.
Ryanlewis2010
Hey guys quick problem i got the mr43t plugs today AND THERE TWO SHORT the block that was in here takes them as a plug but the spark plug holes on this are different an suggestions please help b4 the store closes thanks
Don S
If the seat is not tapered in the head, you need the AC CR-44N spark plug.
How long are the treads in the head?
Ryanlewis2010
the ones i pulled out of the running motor are about 1in and the ones that are supposed to be in there and out of the other head are about .5in here is a pic2012-03-23_18.59.48.jpg
Don S
That's because the head on your engine is 20+ years newer than 72.
You need either the AC MR43LTS or the NGK BPR6EFS
Now that we know this, what other things are not 1972 on this engine ?????? Might have a lot to do with the bogging.
Ryanlewis2010
thats wierd but it fits the the old 75 manifold
Ryanlewis2010
will this SP-447 motorcraft plug work its cross refrenced to be a replacement for the ngk version?
Ryanlewis2010
or this ngk is cross referenced to the ac delco PN 2238
Don S
If you would quit cross referencing and get what is supposed to be in there, it might work right.
The long reach plugs should have a tapered seat in the head, does it?????
Ryanlewis2010
Yes it did i found the right plug surprisingly advance auto had the right mr34tls IN Stock so its in and oooo baby is there a big difference in the way she purrs. once i fine tune the idle that thing should be perfect (knock on fiberglass) Thanks don. Still curious on how the whole 20 year newer head still fits the original manifold is this like a vortex head (if they made won for a four banger). would be intersting to hear more about this.
Thanks
Ryan
p.s. the whole cross refence thing is cuz i really want this thing to run so i was being impatient which is all apart of being a teenager haha thanks for your patience
fat fanny
Man I have to agree with Don A/C for GM, Autolite & Motor craft for Ford and the rest for whats left period!!! you will see the difference in performance.
Ryanlewis2010
I see as above but i get what your saying we were typing at the same time
Don S
Ahhh yes, "the hurrier I go, the behinder I get" syndrome.
The manifolds will bolt to different heads, just slightly different port sizes. Things all have to work together to work correctly.
Ryanlewis2010
Funny never heard that before well im about to go out on the water test the new setup out ill reply with the details
thanks ryan
