The starter was making a small grinding noise when disengaging from the flywheel after starting. I saw on here that some oil on the starter output shaft can clear it up. I sprayed some WD40 on the starter teeth and output shaft and went to the lake. Tried to start the boat and the starter whirred for about 1 second and then nothing. Now it is totally dead, whenever I turn the key all I hear is a clicking noise. I checked the battery (which is brand new) and it is 12.75 volts sitting and 12.6 volts when the key is turned to start the boat. I am getting 12.6 volts at the starter as well (checked the power cable where it screws into the starter). What is going on? is the starter shorted out or is there something I can do to fix this?
