HELP: Swapping a Merc 3.0 Alpha 1 Gen2 with a Merc 3.0 Alpha 1 Gen1 Motor
heebeha
Does anybody have any insight into what I will need to do/change to swap a Mercruiser 140 3.0 Alpha1 Gen2 with a 140 3.0 Alpha1 Gen1 engine?
I have a 1999 Bayliner 1950 with a Mercruiser 140 3.0 Litre engine. I need to replace it. I found a strong running 1989 Mercruiser 140 3.0 Litre engine that I want to use. I was told I need to check to make sure it will drop in before I buy it. He says the bellhousing and flywheel may not line up, but he's not sure. I am hoping someone here has done the swap and has experience with what snags I may come across.
Any advice would be greatly appreciated.
Thanks in advance.
Jeff
xltier
Re: HELP: Swapping a 3.0 Alpha 1 Gen2 with a 3.0 Alpha 1 Gen1 Motor
gen 1 and gen 2 are mostly referring to the outdrive and transom stuff.
heebeha
Re: HELP: Swapping a Merc 3.0 Alpha 1 Gen2 with a Merc 3.0 Alpha 1 Gen1 Motor
Any idea whether it will bolt in without issues?
I need to know if the flywheels are different, if so can I simply take my old one (1999) and bolt it on the 1989's crank and if the bellhousing is different, will my (1999) bolt on the 1989?
Will the mounts align?
heebeha
Im in a real bind here. Any help would be greatly appreciated
Ayuh,... If you have both motors sitting side by side, you'll have enough parts to bolt either 1 in...
mariner1900
There are 3 main things to check:
1. Check the centre distance of the rear mounting bolts on the "89" engine and compare to the centre of the '99 engine. Should get 9.5" and if both the same then the '89 engine will sit on the transom plate.
2. Check the exhaust positioning to make sure the '89 will match with the position of the '99 exhaust.
3. Check coupling type on both engines
Fordiesel69
I think the flywheel and coupler will just swap over with no issue. I have not read of any balancing issues. The exhaust may be different but if so just swap over the manifold.
Simoniz
To the above list, I would add, Check the height from the centre of the crankshaft to the loadbearing faces on the engine mounts - to ensure that you will be able to get the drive to align to the engine.
heebeha
Thanks everyone. I am really looking for someone who has done this before. It does not look like the flywheel bolts line up. I matched them and it is off.
Also if I do swap the flywheels somehow, wont it throw off the balance of the crank??
Does anyone have any hands on first hand experience with this?
Must be someone out there.....
Thanks again.
Ayuh,... Why are you swapping flywheels,..??
heebeha
auhhh i dont know
heebeha
Why do i have to swap the flywheel and coupler? My 1990 flywheel will not fit the 1989 crank. The bolts dont match up.
mariner1900
Your flywheel from the '99 engine probably will not fit the '89 engine. I think the '89 has a 2 piece rear seal and the '99 engine has 1 piece seal therefore flywheels aren't interchangeable.
The '89 engine should be a drop-in.
I am currently fitting a '92 engine into my boat to replace the '74 engine.
I need to fit a modified flywheel so I can use my '74 flywheel housing and starter motor so I can mount the engine as the '74 mount centres (14.5") are different to the '92 mount centres (9.5").
You should be able to just drop the '89 engine in as the rear mount centres should be the same, i.e both 9.5".
heebeha
Thanks Mariner. I am going to measure the bellhousings and report back. If its off I can always shim the bellhousing up or shave it a bit if its not to much off.
mariner1900
The measurement you need to take is between the centre of one of the rear mount bolt holes to the centre of the bolt hole in the other rear mount. This should be 9.5".
