Help Test OIL/Water Gauges, overheat alarm.
lmannyr
Re: Help Test OIL/Water Gauges, overheat alarm.
Picked up a BRASS "T" and a Oil pressure switch from a local auto parts store. Pulled out the fuel pump switch. Screwed in the "T". Put the Fuel pump and oil pressure switch on the "T".
Wired it up.....Voila!! WORKS!!! Without starting engine with ignition switch in the "ON" position, alarm is on. Engine on, alarm is off!! GREAT!!
Now if I can only figure out how to put a delay on the alarm so it wont turn on during start up.
THANKS Everyone.
