Help.... the ethanol in my gas ate up my doel fin... does it really do anything????
Maclin
Re: Help.... the ethanol in my gas ate up my doel fin... does it really do anything??
:laugh:
81_chapparel194
but it ALL really depends if the stringers rotted first or the deck..
coolbri70
sounds like not enough rollers on yer bunks:facepalm: you need to back up until the tailpipe is submerged:rolleyes:
southkogs
... and all this because you insist on power loading. :tsk:
oldjeep
If you had taken a water test with a surveyor this never would have happened
fishrdan
This wouldn't have happened if you used Stabil!
But seriously, the damage was most likely caused by the plastic fatigue due to road vibration while towing. You need a deflopperizer to keep it from happening again.
I would suggest repairing it, but that would bring up a bunch of bickering over whether to use poly resin or epoxy, when the clear answer would be to use Gluvit. Gluvit will microscopically fill in all the fractured (fracked) plastic and hermetically seal the pours.
bruceb58
Next time rub SeaFoam on it. Snake oil preserves snake plastic.
Home Cookin'
ayuh...'n fer got'n garble 'n wargle fer 'nuddin'...ayuh
SigSaurP229
Might as well go ahead and check the muffler bearings while you are at it too.
Maclin
All for naught if it was not properly winterized.
Maclin
Metric, betcha bought it off Craigslist.
hungupthespikes
Master Chief Petty Officer
You need to keep the exhaust away from the fin. THEY recommend thru haul exhaust.
Maclin
Metric, did you use the correct alignment tool?
Maclin
Lots of good advice, may need to request this to become a sticky.
imstriker
Did you drain the water out of the plastic before winter or fill it with antifreeze?
Knot Waiting
If you don't drill a blow hole in those dole-fins they suffocate.
bruceb58
Doel-Fins apparently only work on Stingray boats so if it isn't a Stingray, might as well remove it anyway.
V153
I bet a Manatee ate it ...
Home Cookin'
Another reason not to have carpet in a boat. Look what happened.
