help to identify modle and year by partial serial numbers (warn sticker)
Lund_bC
Hi !
I have a new to me Johnson, what I think is 60 - 70 hp, mix your own oil in the gas outboard the owner said was "mid 80s"
the best i can get the numbers off the sticker, as it is warn out, are as follow :
Model # E40AELCC8 (the last few numbers are hardest to read)
and
Serial J757737 ( all numbers are hard to read)
Anyone have a good guess what model, Year, HP ... you might find from this ?
Its kind of hard to get parts when you don't even know exactly what your motor is.
Thanks everyone !:D
Joe Reeves
Re: help to identify modle and year by partial serial numbers (warn sticker)
E40AELCC8 = 1988 40hp Evinrude, Electric Start, Long Shaft.
Lund_bC
um.. weird, maybe the sticker fell off and someone slapped another ?
Strange.... anywhere else you can find the serial or model number on the unit ?
boobie
Is it two or three cylinders ??
Lund_bC
Its 2
Joe Reeves
(E40AELCC8 = 1988 40hp Evinrude, Electric Start, Long Shaft)
um.. weird, maybe the sticker fell off and someone slapped another ? Strange.... anywhere else you can find the serial or model number on the unit ?
Explain, describe what you have. Why is this weird? Look on the powerhead for a small quarter size core plug that might have the model number on it.
Lund_bC
I just find it weird that the motor cover says johnson but you say evinrude. Are they the same really ?
Joe Reeves
Yes, just like Ford & Mercury.... different colors is all. Someone has either installed a different powerhead or changed the hood. Did you check the powerhead for a small core plug (looks like a small freeze out plug) that might have a model number on it?
The "E" at the beginning of the model number indicates "Evinrude". If a Johnson, that letter would have been a "J".
Lund_bC
I think I found the freeze plug with a number on it like RBH 043201, does that make sense ?
Thanks
Joe Reeves
The "RBH" is instead no doubt "RPH" (Replacement Power Head) which tells one that the powerhead has been replaced, but other than that..... tells us nothing more.
Lund_bC
I guess I will have to keep digging, it looks like a mid 80's johnson that I can see in pictures, but I need an impeller so having trouble with that.
Maybe it is a 1988 like you said and the johnson cover was bought later or something....
