Help! Trim And Tilt Stopped Working.
mieyk
The motor is getting voltage 12.5v in up and down and you can hear it making noise but not the usual up or down noise. It is very quiet and if you hold the up or down button for a few seconds it will start making the right sound and move a little (like an inch) but fade out kind of like the battery is dying. The battery is fully charged and i replaced all the fluid but it still does the same thing. the manual release was loosened and the motor was manually raised and lowered to try removing air pockets. Still does the same thing. could it be the pump or pump coupler? I really dont want to take the tnt out.
BTW its a 89' 140 johnson v4 looper with the showa 2.4" motor.
donnyskz1
Re: Help! Trim And Tilt Stopped Working.
sounds like you have a bad trim motor
mieyk
is there a way to get the motor out without pulling the entire tnt assembly? I cant get the tilt tube pin out...its stuck pretty good.
