help verify model number and manual for Sea King clinton 7.5 hp motor
WDT
Hey folks I'm new to the forum. I am helping my son with his first
outboard which is a Sea King Clinton 7.5. I thought it was a K751
according to listing on Discount Marine 1977-1979. I ordered that
manual but it is the wrong one. The K751 shows a slide throttle in the
front of the cowling this motor's throttle is regulated by the tiller
handle. The model number is K7515106B, Type number XTV50575B SN
1513168. I have attached pictures if any one can help I would certainly
appreciate it. I assume the water pump impeller is notoriously bad the
design looks less durable. At any rate we had to replace it and boil
the carb out change the plug and were good to go for awhile the nylon
gears that mesh between the tiller and throttle linkage broke. I found
them at discount marine for $10 each. Any suggestions for other places
that may have a good supply thanks.
brim_buster
Re: help verify model number and manual for Sea King clinton 7.5 hp motor
Its a 1977 according to Langs chart 50575 SN
WDT
Hey brim_buster appreciate the input do you have a PDF for the manual for this motor. I ordered the K751 but it is the wrong one. This motor has the throttle at the tiller handle. I think I heard it called the Sea king Chief
brim_buster
sent you a private message...
Speakrdude
Ensign
Hey, Can I have a copy of that too? Or at the very least, what spark plug does it take?
Thanks!
Speakrdude
Ensign
Well, I think I have the spark plug figured out but, I need some visual references to put the carb back together.
In particular, the little spring that goes on the float shaft. Also a couple of other small details.
Anyone have any diagrams?
Thanks
(Mid 70's Wards Sea King Clinton 7.5HP)
