HELP w/1998 Mariner 50 4 stroke Big Foot Lower Unit
snooks2005
Re: HELP w/1998 Mariner 50 4 stroke Big Foot Lower Unit
yeah everybody seems to be out of ideas :) what tuneups would you suggest?
BillP
Two suggestions...reduce the prop diameter and use a 4 blade prop on jackplates...pitch way up if you are mostly running with the jackplate up. Put a Doelfin on it. The Doelfin let me get approx 5 mph faster just by letting me trim higher...expecially so if you are using a 3 blade. Don't forget the low water pickup and presure gage when getting this high.
snooks2005
BillP.....I have already tried the smallest diameter 4 bladed prop that power tech makes which is a 12 3/4 x 12 pitch. So what you are saying is to have the diameter of this prop reduced?
BillP
You need less diameter and lots more pitch to make approx 6000 at full throttle while jacked up. If you can't find a stock 4 blade look for a 3 and size for around maybe 18 pitch. This stuff is really trial and error. Math only gets you to the starting gate. <br /><br />Your 3 blade may be much better if you try the Doelfin...I would do that before anything else. The one I added made a whopping big difference at top end. It reduced cavitation/ventillation a huge amount when trimmed up. You have another 400 rpms to play with...presuming the max is 6000? I currently have a Mariner 50 4s with 2:0 gearcase and the max is 6000...3 blade propped at 5600 on a 20' pontoon.<br /><br />I ran in a hardcore flats boat that was pitched at 27 (yes 27)on a 4 blade. This one had a 175 Merc and all the go fast goodies for shallow running. It literally screwed through soft bottom in ankle deep water at 45mph with 2 up...it ran 65 in clean water. It was a 20 "Crossover" (650lbs kevlar)and made in your neck of the woods.
