help w/ Johnson 93' 150 hp faststrike???
soccplayer07
Hello all. I finally took my new/used ranger out tonight. I had a horrible time getting her going. She cranks and turns over. She will idle ok. The minute I start giving her gas she dies. This continued for about 30-45 mins. Finally got her going. Ran her for about 30 mins. She feels very jumpy. Give her gas and no response... 7-10 seconds later she jumps. We shut her down and tried to start her again and the same thing happened again. Very difficult to get her going. Before buying the boat I had a mechanic come and check everything. Compressions checked out. fluids looked good. She started up (w/ muffs) and ran well. So what gives??? I changed the spark plugs (as directed). I think it could be the fuel line, throttle or dirty carbs (sat atleast a year). Any of those fit the symptoms??? I think fuel line b/c "ball pump" never stays hard. Please give me ideas. I am very frustrated being that this a first bass boat for me.
GeneMachine
Re: help w/ Johnson 93' 150 hp faststrike???
I would definitely get a new ball, especially if its not holding the pressure, most johnsons need about 10lbs of pressure, but i would also clean the carbs as well since its been sitting
soccplayer07
i'll look into that today. Any other ideas?
GeneMachine
make sure you have fresh gas and clean the carbs really well
jonesg
So what changed from the mechanic starting it to you starting it,
different fuel?
when I got my boat last yr ( 150 hp) I immediately changed all fuel lines, new bulb, new temporary tank for testing, fresh fuel , new plugs, new fuel filter, removed prop to clean and regrease shaft, changed lower unit oil,
and that was before trying to start it.
After test running with a mechanic he suggested a power pack and rebuild carbs, did both and it runs nice.
Used engines are usually an unknown quantity so I wanted to make sure everything was covered. It really pays to go through a new to you engine before getting on the water. Bring everything up to snuff.
Unless the previous owner was meticulous and had the reciepts to show it, I just assume it needs a good going over.
jonesg
different fuel?
