jldsomething
Thread starter- Joined
- Sep 12, 2011
- 19
i started my boat up this year with the muffs on and it wasnt peeing much water out then i noticed a stream coming out of the middle of the propeller. i also noticed it dripping from the left side of the engine where the thermostat is and spitting out of the exhaust ports. i tested compression and it was good on all three cylinders so i took it appart and noticed a striped stud on the water pumper so i used the tap and die kit and fixed it and put it all back together i think its stoped coming out of the prop i stuck it in a barrel of water this time thinking maybe the hose was just giving it to much pressure. i still have it coming out of the exhaust just like spiting. also it was running kind of bad i was guessing water was blocking exhaust port and not allowing enough air flow usually it runs like a top.
my guess is blown gasket between the exhaust and water ports on the left side where the thermostat is iv already got all new stuf on order for that but i was still worried about water coming out of the prop. its not now but is that a normal thing ? should i replace some seals in the lower unit or anything? i cant find any real info to help me out hoping someone could help me i just dont want to mess up the lower unit iv put to much in this motor anyways. thanks.
