Help wiring wagner modle dc-60 alternator on 470 3.7 or the 224 its one wire
bigdaddtpugs
i found a post by Don S BUT WHEN I CLICKon the link nothing comes up found in the adult only section
Fun Times
Hopefully Bt Doctur will be able to give a helping hand as he's pretty good with these type of questions.:)
In the mean time, I can't seem to locate the link you're mentioning. Any chance of you copying the "name" of the link and posting it here in order to see if it can be located and repaired. Thanks.:)
PS, you may need to post a photo of your alternator connections. Good luck.:)
bigdaddtpugs
its under the Aduts only page then click on #2 MERCUISER INFORMATION scroll down to page 2 and it the 470 page . the post #or ml#post4045962 is what it say in the box
Bt Doctur
do you have the old charging system removed and water cooled regulator removed?
bigdaddtpugs
No Title
Yes.
Bt Doctur
If that red wire is coming from the alt and is going thru the 90A block at the starter terminal ,then it looks good
bigdaddtpugs
What side of the fuse does the red wire go on. What wires go to the slave solenod .
Bt Doctur
on a typical motor that uses the ford type relay the yellw/red stripe goes to the left side if you face the relay and the small lug to the right can go to ground or depending on the type of relay used ,to the pos side of the coil. this will supply full voltage to the coil ONLY during the cranking phase.
Bt Doctur
GA_Boater
Hope this helps. The full schematic, after and before;
bigdaddtpugs
No Title
Here some pictures. N thanks to everyone for taking time on Easter for the help Will the three wire work on a one wire N do I need to ground the alternator with the bolt on the top right in thr picture
bigdaddtpugs
No Title
Is this the right way to wire it up went from both diagrams
