freeisforme
- Joined
- Mar 23, 2009
- 184
Re: Help with 15hp Gamefisher (Force)
I've got one of those motors, mine is a 1989, 15hp Gamefisher but has no spark. My compression is 110 on both cylinders, and was told that that was low in another post here. I've got an older Chrysler built Sea King 9.6hp that looks to be a very similar motor that has 140+ on both cylinders.
The Gamefisher 15 I have looks mint clean and rarely if ever used.
I'd like to hear from some others as what sort of compression numbers these things should have.
I've got a Johnson 5 1/2hp from 1964 that only gives me 65 psi on each cylinder that runs just fine so I know a motor will run at lower compression just so both are the same.
I went so far as to take a look inside mine with a borescope, which I have access to at work and all looks great inside, no scoring or rust.
I would think that if the compression was too low, you would first notice it when in the water vs running with the exhaust exposed in a barrel or on ears. If mine does indeed have low compression, then yours is just plain worn out?
I got mine for free, so anything I put into it is all I'd have invested, so I'll most likely spring for a new ignition system unless I can find a parts motor.
There was a few used motors on eBay but not local, and one earlier power head which I'm not sure will work on the '89 or newer motors?
I'm guessing that mine will gain some compression after it's up and running, since it's been sitting for 20 or so years. It's already showed improvement just after me cranking it over and over testing for spark. I may pour some Seafoam or penetration oil down the cylinders and let it soak for a few days in case the rings are stuck on mine from sitting. My guess is that it sat untouched for all those years and anything that was shot into it when it was put away is long gone by now.
