huskerdaninva
Thread starter- Joined
- Jun 18, 2009
- 240
Hey again y'all. I need to pick someone's brain who is more knowledgeable than me. I have a 1969 Chrysler 70 hp that I brought back to life last fall with much help from you fine folks. I'm currently in the middle of doing pre-season maintenance on the powerhead and lower unit.
Eng. Model # 7071 / Serial # 5145.
I've already ordered a new impellar and have new check valves coming for the fuel pump. My issues start with the thermostat and cylinder head. On my motor one has to remove the cylinder head cover to access the thermostat. There is no separate cover for the thermostat.The bolts that hold the head cover go thru to the block and also secure the cylinder head too. I need new gaskets and I have found that the part number for the head gasket is 18-3855 and is available for about $30.00. Does anyone know a part number for the thermostat and the cylinder head cover gasket. This gasket has portions that extend across the diameter of the circular open area. (Hope this makes sense.) All of the charts that I have found list Chrysler 70 hp only as far back as I believe 1977.
OK, now if I can't find a gasket can I use permatex in lieu thereof? Same question on the gasket that goes under the metal plate under the waterpump impellar? Will permatex or something else hold up or are gaskets the way to go? Oh yeah, is it safe to use teflon tape on the threads of the vent/fill plugs on my lower unit? They seem to be seeping a tad. Is there a part number for the plugs available? Thanks I know I'm being a pain but this board is such a vast wealth of experience and knowledge. Thanks in advance for any help!
Dan
Dan
