Help with '72 Chrysler 55 Flywheel Swap
jtbull
The flywheel key sheered and badly gouged the inside of my flywheel. My parts manual shows three ignitions for the 55's. Mine is the magneto (ignition coils under the flywheel-no alternator). Can any one tell me if either of the flywheel from Magnapower (CDI) or the standard (battery operated with secondary coils on the outside of the power head) will work on mine? The parts manual shows two different part numbers, one for the magneto, and another for the Maganpower and the standard ignitions.
Thanks in advance, Jeff
Frank Acampora
Re: Help with '72 Chrysler 55 Flywheel Swap
The flywheels are completely different. You MUST use the one for magneto ignition. See my private message to you.
