after eliminating potential battery problems(had them load tested) i am at a standstill on my motor problem. i tested my battery voltage and it read 12.3 after hooking up to the engine and starting it, it still registered 12.3 i then unhooked the battery(my engine continues to run) and tested the return cables and they registered 0. i know very little about engines but was told to do this to see if the problem exists in my batteries or my engine. i was told if they don't read in the 14 range while the engine is running, that the problem lies in the motor.<br />is this true?<br />any suggestions?<br />and if so, what is the next step to take to diagnose my problem? thanks
