Re: help with '90 3.0l 4 cyl tune up.
You don't have to replace the plug wires unless there is a problem with them. Of course if they are original it couldn't hurt.<br />Along with all the parts, do you know how to set the dwell, then check and reset the timing, how to check the advance timing, how to adjust the carb idlespeed and mixture? Do you know what the specs are for your engine?<br />There is more to a tuneup than just putting the parts in that someone says get to get.
