Help with a 130 on an OMC SeaDrive
emoney
So, as you can see in the pics, the motor's original bracket is removed when it's installed on the SeaDrive Tilt unit. I'm assuming that's where I would've normally found a Model number. Where else can I look? The person I got the boat from wasn't the original owner and while the bracket is original, pretty sure there wasn't a 130 hp model in 1988, isn't that correct? It doesn't seem like a different "hood" and it's got most of the other tell-tale signs of being a 130. If so, that means someone swapped out the motor for this early 90s version, but before I get into tearing it down, I need to know the model for parts purposes. Where else can I look?
