I recently bought a boat that came with a 70 hp 3 cylinder model 650 engine . The cowl says it has thunderbolt ignition . It has good compression but no spark on any of the cylinders .I have disconnected the tilt switch and it made no difference. My research so far has led me to believe that bench testing the switch box is not a option. Is there a way to bench test the trigger? Could the rectifier be the problem? Can it be bench tested? I suppose all three coils could be bad but that seems unlikely. I have checked all the wiring, and the ignition switch, they seem to be fine. Any insight would be appreciated. I will post some pictures as soon as I can . thanks
