Help With A Evinrude
spicerak
1989 150 Evinrude Xp I See Where The Thermoatats Are They Have A Wire Coming Out On Both Sides One Is Broke Out Of It What Are They For.also I Was Trying To Get My Alarm To Work It Isnt I Tried To Groung The Broken Wire And No Sound What Should I Do Thanks.also I Had The Key On Too Where Is The Alarm Do I Need To Change Thermostas To Fix Wire
ezeke
Re: Help With A Evinrude
The horn in the remote control is the warning horn. Each cylinder head should have one overheat switch connected to a tan wire that runs to the remote control through the harness.
The horn is wired directly to the positive side of the ignition switch accessory post; the alarm system works by providing a ground at the engine when there is a problem.
The switches are off or on. If they sound the horn, shut the engine down immediately. If they are not functioning, you should replace them.
See the article here and scroll down for the diagrams:
http://continuouswave.com/whaler/reference/ignitionSwitch.html
spicerak
The Top Of The Three Spark Plugs Is The Thermostat Yes Or No?if So What Is The Wire There For Coming Out Of It And What Do I Do If Its Broke Out Of It.also How Can I Test The Alarm Thanks
emdsapmgr
The head temp sensors will go to ground at 212 degrees, sounding the horn, then open back up when the temp gets to 175. Normally they are open. You can pull the rubber cover back off the wire sensor lead's knife electrical connector. Grounding the harness end to the block when the key is on, should sound the horn. If you don't get a horn, you can check the sensors per the factory manual. Make sure to check the horn, too. Yours may sound the horn for a few seconds when the key is first turned on-if so, it is ok. If you have to replace a sensor, you don't have to pull the head, only the head cover..
spicerak
ok the wire pulled out of the head cover should i just replace the sensor and do i have to change head gasket.alsothat wire where should it go it seems that the wire just goes to the sensors and no where else is did try to groung the wire that pulled out and i did try to ground the other side with key on no sound and no sound when i first turn key on.where would the horn be for my engine 1989 evinrude xp 150.by the way thanks i getting closer to fixing
