Help with Bimini top frame
jaybirdtoo
I just replaced the top on my pontoon boat. Took the top and frame to a canvas place they replaced it, I put it back on the boat at the slip. OK here's is the problem. The new top is very nice But frame is tweaked. How can I get this back to be straight. Can't seem to just bend it back. Any help. Thanks See pictures The back is ok the front leans to the right ( looking from the front )
guy48065
Is the frame tweaked with the fabric removed? If the cover wasn't laid out symmetrical and square it will distort the relatively weak frame.
ahicks
I say show these pics to the people that made the top. If they can't figure out what the problem is, seems like they'd make you another one?
airshot
Adjust the tensions on the hold down straps, if this won't fix it, the top itself is off.
jaybirdtoo
Thanks everyone for your help. I already removed the top before and the frame was still out of line with the back frame. So today I remove one side of the front frame and bent it out about 6 inches reattached. Then did the same thing to the other side except I bent it in about 6 inches.
Readjusted all brackets and hold down straps and yippy, it looks almost
perfect. Thanks again
Bimini top frames are bent by hand around wood forms. Easy to tweek
