Help with Damaging Leak
rons boat
My 23 Foot compac started leaking in the cocpit area down below through several bolt heads, side pockets, and maybe a few instruments. I am using marine silicone between showers but it just keeps on raining. I am not sure why the flood all of a sudden but need advice on what best to use to seal. My beautiful original upholstery has been removed and I hope to save though it may be too late on some of that. Some of the furniture has turned black in spots, but I can save most of that. I hope to stop this all of a sudden situation. Is there something better than marine silicone?
rons boat
Re: Help with Damaging Leak
Haven,t been checking this forum lately. Anybody sailing a Com-Pac?
flashback
Ron, in most all deck leaks, you need to remove the bolt, stanchion, instruments, etc,,, completely and then bed them in a good sealant.....most boats from the factory are not sealed well.......they just don't take the time.........
Columbia
If what you're looking for is temporary respite during the rains, you have to use a sealant designed to go onto wet areas. Silicone is NOT that sealant. However, once silicone is applied it makes it much harder for other sealants to adhere. However, I recommend you go to the local lumber yard and see if they have a sealant with a silicone element that is labeled to apply wet or dry, I saw one yesterday so labeled as I was buying caulk for my garden shed project. When the rains cease, you must remove the offending bolts and what they bolt through, properly clean the surfaces, and rebed. I don't recommend a silicone product. Use a marine caulk properly formulated for that application. You don't want a polyurethane adhesive sealant, just a good marine caulk. The silicone has to be removed cleanly before you recaulk.
