Hi all. I just changed the impeller on a evinrude 15 and put it back together. I hooked up the muffs and fired her up. I noticed that there was water coming out of the area where next to the lower unit where the shift rod goes into the lower unit (the area below where the motor rotates on and has the grease zirks) also there was water shooting out sideways from a hole near the front of the lower unit prop assembly. Does this sound normal. There is a good stream exiting the pee hole behing the motor but I'm concerned with this extra water.<br /><br />Thanks,<br /><br />Colin
