Help with Evinrude ground cable
Ymtejera5
Good afternoon.
I just replaced the water tube and im putting the motor back together. However there is a ground cable that connects to the plate above the rubber mount, when taking it apart that cable was ripped and never saw where the other ends connects. I need some help identifying where it the other end goes.
Cable is part labeled 14 on the following link
saltchuckmatt
Good afternoon.
Pretty sure it's just going from the block to the lower cowlings. Doesn't matter where and I believe you should have another one at another location.
Crosbyman
Good afternoon.
engine mdl # ???
Ymtejera5
Good afternoon.
Update. After scouring the internet and looking at various service manuals I figured it out. This is just a grounding cable to prevent corrosion. Goes from that plate to the lower engine cover. Thanks for your help.
saltchuckmatt
Seems like someone mentioned that.
