Help with extremely tight steering.
kmcgillis
I know the steering should be tight but I am a big strong guy and I have trouble turning my boat at times. My wife cannot drive it at all because of this. I have a 99 Javelin Renegade 18 with a Johnson 150. It does not have Hyro. steering and it turns left easier than it turns right.
Is this normal or is something worng. Is there anyway I can adjust how tight it is. I have tryed greasing the bars by the motor with no change.
Isaacm1986
Re: Help with extremely tight steering.
Sounds like you have a stiff steering cable. Depending on the style of cable it is, there should be a grease fitting at the top or bottom of the cable to grease it up. Otherwise it might be time for a new cable.
ufm82
Master Chief Petty Officer
Cable steer systems typical turn one way or the other easier because of prop torque- it will push the engine in one direction depending on the rotation of the prop. A right-hand turning prop will push the engine to the left, causing hard steering in that direction. The trim tab behind the prop is there to hel alleviate some of that. Adjust the fin to counteract the torque and that will help with steering effort.
A dry/corrode/damaged cable will also cause hard steering in any direction. The cable end at the engine will often get a bath when you shut down and the wake wave comes over the stern- the cable and sheath get soaked and water can get in the sheath, causing corrosion. If that is the case, take the cable end off the arm that connects to the engine, extend it all the way and clean/lube it. If the corrosion is in the tilt-tube, you'll need to remove the cable completely from the tilt-tube and clean out the passage. Some boats will require the removal of the engine from the boat to get the cable end out. (Mine used to need that until I made a modification.) Run a cleaning brush through the tube and scrub it clean- it can take a good bit of work to get it clean. Then lube everything with a good waterprood grease and renstall everything.
A good cable should provide easy control- if you are having hard steering there is typically a reason for it.
UFM82
dsiekman
Pay very close attention to your steering cable. A few years ago my fishing buddy was trolling in his 20' CC when the steering cable snapped. Luckily he was only doing about 3mph. He had to "bear hug" the outboard about 8 miles back to the ramp. Could have been bad if he had been on plane...
