missinglink
- Joined
- Jun 2, 2011
- 19
Hey guys, So I have been trying to do the bellows job on my 165 mc-I. The problem I have run into is getting the hinge pin out of the left side. I tried the special tool broke 3 of those tried a 1/2 inch allen and stripped the pin head. Tried drilling through it and using easy out the tip of that broke off into the bolt and cannot drill through that at least not very well. I had a welder weld to the pin and they tried removing it that way broke 4 times. Tried propane first then mapp gas and the welder tried some kind of heat. The problem seems to be the pin doesn't move when the lower moves its more like it threading and unthreading at the bolt. SO Now I am completely out of ideas and wondering how to remove the gimble ring itself and maybe try bringing to a machine shop or buy a replacement on ebay.
Can I remove the gimble ring with the bell housing still attached? And how?
