Help with hesitation - Mercruiser 5.0 carb
Brian 26
I just bought a 1999 Bayliner 2350 Capri with a Mercruiser 5.0 Carb Alpha 1 engine and outdrive.
The seller told me it hesitated at high speed and high acceleration and had been that way since he bought it 7 years prior. On the test drive I did not notice any hesitation but it was hitting the rev limiter with the 17p prop that was on there. I bought the boat as is for a very low price and switched to a 19p prop which has helped the rev limiter situation (I probably should go up again to a 21p).
Now when I accelerate from idle to full throttle when the engine is below operating temperature it will hesitate a lot and I have to let off the throttle to get it to go. Easing into full acceleration seems OK. I do not notice the problem when the engine is at full operating temperature.
The seller has maintained the boat well and had a mechanic test drive it who supposedly said he thought the issue might be a "hidden fuel filter" that no one ever thought to change (seems unlikely to me).
I'm looking for ideas on how to proceed, my thought is start with the easy stuff first and eliminate possible issues:
vent to the gas tank may not be working correctly
Clean spark arrestor
Change the fuel filter (possibly clogged or water in it..maybe water in the tank)
look for other things slowing the fuel flow (kinked line or this infamous hidden fuel filter)
Spark plugs
Spark plug wires
Clean carb
What would you guys do?
JaCrispy
Full tune up (cap, rotor, plugs and wires), fuel filters, rebuild carb. If that doesn't fix it then begin investigating or tuning. But all the other stuff is done. You can't tune a broken engine.
thumpar
Since it doesn't happen at full throttle I would doubt any issues in the fuel supply. My first guess would be accelerator pump. I would start with a carb rebuild.
Ayuh,.... Agreed,.... Sounds like the carb needs a rebuild, or replacement,...
DaveG55
If the issue is only there until it warms to operating temps then I'm thinking carb too. Maybe a slow opening choke.
NHGuy
I'd say don't run it hard til it's warm anyway. I agree that it won't run as well under bigger loads til the choke is open.
callen369
Agree with carb....but a simple compression check is a good way to see what's going on in the motor. The plugs may give you an idea if you are running lean or rich by color...and if you have low compression in one cylinder or more, then that can point to a head gasket, valve or combination of trouble. If they all pass and plugs look good, then you know you have to dig a little deeper into it. Carb, fuel issue (start with running off a gas can) maybe even ignition related.
Thunderbolt V ignition?
Brian 26
Thanks for the advice, the boat is in storage now but I will dig back into this in the spring.
I agree but I if there is an issue I'd like to stay ahead of it and get everything up to where it should be.
