help with high voltage
arcrat
Verado7 please help 1987 3 cyl 90hp mer over charging 16+volts need part number for vr/rec.......thanks for infor:: arcrat
crappiejig
Re: help with high voltage
Rectifier is pn 816770T, however yours is working since your getting 16 volts. I believe your charging system is unregulated and 16v is about right at higher rpms. My 1989 60hp motor is unregulated and i see 16v routinely.
arcrat
Thanks Cappie Jig..what Do You Think About Running Two Batt Connected Togeter? Thanks Alot... Arcrat From Okc Ok-----
