nonninator
Thread starter- Joined
- Aug 30, 2009
- 19
I have searched already...just puttin it out there...I have a volvo penta 5.7 (chevy) carbed motor, prior to rebuilding the carb I was only running on 2 primary barrels, so I assumed bad secondary pump daiphragm, so I rebuilt the carb. Simple. Now I put carb back on and she won't start. I've fiddled with idle screws and all...there arent any needle screws on the secondary metering plate are there? if so there's my prob cuz I don't have any. I put everything back together and went to crank her up...she started, choke is set right on the money, then she ran real rough for 3 sec. then died and the aft 2 barrels(secondaries) were closed of course and there was fuel dripping in them but they were full of fuel and the primaries were seaping vapor...WTF...what causes this? what should I try? Its def. something with the carb...please help me I've been messing with it for hours upon hours..thank you...also for idle mix screws I've read that 1 1/4 turn on each side is a good starting point...should I adjust them until smooth running or what?
