mrwiggles2
Thread starter- Joined
- Aug 26, 2008
- 70
Another thread indicates how I reversed the poles on the battery and fried my CD unit. I found a new CD Module never used old stock at a local dealer (lucky). I went to hook it up but think I'm doing something wrong.
I hooked the red/white/blue wires up correctly on the terminal block as I had it written down where they went exactly. My distributor has one contact point, so it is a breaker point. I believe the white wire with black stripe from cd unit goes to the distributor contact point. However, I had a short black wire with an eye on each end hanging there from the distributor contact point, (like the one that came with my CD module) not sure where that goes.
The cd module has two other short wires, one greyish that went to the + side of the coil the other black, that went to the - side. Then I have another short wire ground I assume that goes from neg (-) side of coil to I guess a ground on the distributor.
Turned the key last night, heard the choke solenoid engage, but when I turned the key, nothing- sounded like the starter wanted to turn but nothing happened. Something isn't right. My manual (seloc) doesn't have a clear breakout of hooking up this CD unit- hopefully I didn't destroy something else in the process of reversing the cables.
