help with ignition - 1948 goodyear/gale 5hp
CamaroMan
Hi all - busy trying to familiarize myself with a motor i picked up 2 days ago -
I have thus far followed this article to test my coil:
My primary is 100 ohms (unless i misread sth on meter) and secondary is 3700 on both coils..
According to condenser tests they also passed -
I set the 2 coils according to this with my A gaps at 0.012 and B gap at 0.014 - I measured business cards till i had 2 sizes, marked them and slipped them between coil and center part.
When I spin motor, I do feel a buzz from both wires, but nothing jumps to ground when I hold a wire close to metal - fyi im spinning the motor with my cordless drill and plugs removed..
My coil looks exactly like this one:
RCO
Those coils are usually good unless physically damaged. It's a good sign that they both have the same reading, although I think your meter is on the wrong scale. How are you checking the condensers? Did you clean and adjust the points? As a test you can disconnect the condensers and check for spark, just don't run it like that it it will burn up the points.
CamaroMan
Hi- havent cleaned the points yet.. will get to it 2moro probably.. I was running a max ohms test (to excite the condenser) - then connected a 400milli volt prongs and watched the volt drop slowly down, disconnect a little, and watch the voltage is where it was when I disconnected (to check it holds the charge)..
I have a few new condensers as I work on older boats quite alot so ill put new ones in, get new plugs and try again 2moro :)
I set up the spaces using business cards the correct thickness - hopefully its setup right..
