Help with johnson 50 hp shifter
Hrokor
Ok, one more question. Motor was stuck in reverse no matter what position shift handle was in. Was easy to move lever from Neutral to revers but a little hard to move to forward. Some said to put in neutral, take out the shift linkage screw, shift lever to reverse then reconnect shift linkage. After doing that I put the lever back to neutral and the prop was now free as if it were actually in neutral. I thought it was fixed until I tried to move lever to forward...now lever in frozen at around 11:00 (just out of neutral). Prop still spins freely, but the motor will not turn, choke button does click. Any ideas?
hidef
Re: Help with johnson 50 hp shifter
What is the model number of your outboard? Depending on the year of the controls they might have a neutral safety switch in them. The handle must be straight up and down.
