Skifferskipper
Thread starter- Joined
- Jun 13, 2011
- 35
I Would to ask for some assistance adjusting the carbs on a evinrude engine. I Have pulled the carbs off Cleaned them,New ignition coils, New fuel line and diaphram, Compression is 130 ish in all three ... And for some reason the engine misses at a higher rev. My suspect is that the carbs are not set properly so if anyone could give me tips to adjust my shift/idle/cam timeing/Carb sync I Could really use some adivice Im almost positive that it has something to to with the carbs not being adjusted.. Please help.. Also at a higher rev it seems to be producing Alot of white smoke.. Gotta be the linkage or the carbs..
